How to put Image into a RichTextField?
Hi @all
I want to put Image into a RichTextField using CLI (im createcontent)
    Hello Byeongjin,
    In one of my own Custom Gateway loaders written in Java, I am adding the following tag and it works: <img src=path/filename...>
    But unfortunately, I am not sure how to manage this with CLI.
    Volker
    bkim-21-VisitorAuthor
    I solved the CLI
    command problem with the example code below.
    im createcontent
    --parentID=1061 --type=Requirement --insertLocation=first
    --addAttachment="field=Text Attachments,path=c:/AAA.png"
    --richContentField=Text="<img src=mks:///item/field?fieldid=Text
    Attachments&attachmentname=AAA.png>"
