How to query by issue Type using the API
Hello. I've been working with the API for an integration I am developing. I have read through the Integration Builder's Guide fairly closely. This mostly documents the commands, rather than the available options. I am trying to do a simple im issues command and add an option to specify the type to return like so:
cmd.addOption(new Option("type", typeName));
I found an example in another post on here where the poster was using "type" as an option successfully, but when I attempt this, there is an exception:
com.mks.api.response.InvalidCommandOptionException: im: MKS124819: Invalid option: "type"
Edit: I would be perfectly comfortable with a query that just simply returned all of the Integrity items that I could filter after the fact, depending on their types. The "im issues" command always seems to require an item ID, as I get an error indicating that when I run just "im issues". I just need a command that will return all Integrity items.:
Any ideas what I'm doing wrong?
    mmains-2Answer
    So the solution here was using the "queryDefinition" option. This was conspicuously absent from the Integration Builder's Guide.
    mmains-21-VisitorAuthorAnswer
