How to see the exact Label (size, numbers of labels etc.) at a checkpoint via CLI
Hi @all,
an example: we have a checkpoint 1.2 with label "Test1". Another user adds another label "Test2,Test3" to this checkpoint. If i want to look via commandline with
si viewprojecthistory -P#<projectpath> --rfilter=labeled --fields=labels/<projectpath>
than i get this output:
Test1,Test2,Test3
So i couldnt see if this is one label, or two lables, or three labels. Is there any way to see that there were originally two labels?
Thanks, and kind regards, Jens
    Jens,
    Which version of Integrity are you using? When I test this in 10.2, the labels are seperated by a new line. They appear like this:
    Test1
    Test2,Test3
    I also used slightly different syntax in my command. I used this instead of what you posted:
    Maybe give that a try and see if you get different results.
    JensN.1-VisitorAuthor
    Hi Jeremy,
    we're also using 10.2 (with HF1). And unfortunately also with your syntax i got all labels in one line. So here is my commandline without placeholders:
    si viewprojecthistory --P#/Spielwiese#Test --rfilter=labeled --fields=labels
    and also with this line:
    si viewprojecthistory --project=/Spielwiese/Test/project.pj --rfilter=labeled --fields=labels
    i got this output:
    Test1,Test2,Test3,Test4,Test5
    This is Checkpoint 1.6 in this project, and it has three labels: the first label was set with the checkpoint: "Test1,Test2,Test3", second Label added later: "Test4", and a third label added even later: "Test5". Here a screenshot from the projecthistory within the client:
    Is there any flag maybe in the preferences which can handle this?
    kind regards, Jens
    That information clarifies it a bit. The command lists the labels with each new checkpoint starting a new line. If you have multiple labels on one checkpoint, they will show up on the same line.
