3-Newcomer
How to set the output intent attribut of the PDFX tag on standard.pdfcf file ?
I am trying tp generate a PDFX conform file using Arbortext Publishing engine, and to do so I need to set the attribut outputIntent of the PDFX tag.
I've looked on the documentation and all what it says is the outputIntent must refere to some sort of CDATA. and It appears the it's a file that contains the profile of the distination. I couldn't find furder details about it.
So the question is, how to set this attribut (outputIntent) ? and is there a specific location in where I should place the file ?
