Apr 13, 2021 6:06 AM UTC
How to setup the local environment of Modeler to access Automation Interface via Visual Studio
I have tried to setup a C# project with referenced to ENT6Lib.
But it will always raise an error that the COM classes for ENT6Lib.CCaseProjects not registered.
System.Runtime.InteropServices.COMException: 'Retrieving the COM class factory for component with CLSID {594B0CA2-7610-11D1-BA96-444553540000} failed due to the following error: 80040154 Class not registered (0x80040154 (REGDB_E_CLASSNOTREG)).'
I have install the Modeler with the option client only.
What else need I prepare to fix the problem? Thanks!
Apr 13, 2021 1:53 PM UTC
You may want to post this question here instead,
https://community.ptc.com/t5/Windchill-Systems-Software/bd-p/Integrity
As that sub-forum concentrates on the Windchill (Integrity) producsts (ex.  RV&S, Modeler, IRC)
This forum here, is typically for the PLM product usage.
I would suggest opening a support case for your issue, but I imagine you need to manually register the class then.  Something along the lines of this knowledge article?
https://www.ptc.com/en/support/article/CS229653
If you open a Support case, one of the Modeler support engineers should be able to assist though.
Mike
