How to show images in HTML report
We've been trying to run HTML Reports on objects such as Test Objectives & Test Sessions.
However this functionality does not provide the images (despite of the image's extension) in the report and instead show up as useless broken image icons.
Is there any way to include the images (or links to them) in the report?
Also, attachments in the report are not clickable links. Is there any way to enable users to be able to download the attachments from the report?
Hi Sourabh,
If you are creating HTML reports inside report recipes you can code for images like in HTML you can use <img> tag to add images manually i haven't tried this scenario yet now but i think this way we can do. You can try this case till the time.
Regards
Kapil Jain
