8-Gravel
Aug 17, 2018 5:59 AM UTC
How to simply disable a trigger?
I have a rule based trigger that resets a field on a defined rule.
How do I disable the trigger without reconfiguring the trigger type or even deleting it?
Aug 17, 2018 11:21 AM UTC
Hi Elmar,
Yes, this trigger is getting executed because it has some value to assign based on the rule.
Pre/Post event are only required to execute the script.
So if you want to disable it you can move complete rule to
And
        .......Existing Rule................
        ID==0
Hope this will help you.
Chirag Agarwal
Aug 17, 2018 8:52 AM UTC
Hi Elmer,
You can disable a rule based by simply unchecking the pre/post event(only in case if there is no assignment).
Else you can add one more condition in the rule i.e. "ID=0"
Chirag Agarwal
8-Gravel
Aug 17, 2018 11:07 AM UTC
For the trigger the pre/post event checkbox was not checked but the trigger still did it's job!
Maybe this was because it has no js script that it should run but only a "Rule" that "Assigns" a certain value to a field?
To disable it I now reconfigured it to type schedule as I learned from the support forum: https://www.ptc.com/en/support/article?n=CS148391&language=en&posno=1&q=How%20to%20disable%20a%20trigger&source=search
This did not feel right to me so I wanted to know if there is a better solution.
Hi Elmar,
And
        ID==0
Chirag Agarwal
