How to use "HistoricFieldValue" in script?
I want to check longtext field with its history value.
For eg:
Field Name: Discussion
if(Discussion==HistoricFieldValue("Discussion","July 31,2012"))
Note: I can able to create a get the "Discussion" field history in report using the "HistoricFieldValue" computation. But in Script I cant.
Let me is there is any way to check the field?
-Shankar Daniel
    what kind of script are we talking about ?
    1. a js-trigger skript to run on the server
    2. a client side batch script
    3. anything else.....? ? ?
    Nevertheless in case of 1. and 2. you should try to fetch two whole Items (the "currentOne" and an "historicOne" ) using either the IssueBean(1.) the CLI or API (2.) and than get the "Discussion" field value from the two Items.
    HTH Matthias
