May 24, 2019 9:17 PM UTC
How to use si sharesubproject
I want to share the project /project/A/project.pj to project /projects/B/project.pj, so that the final result is /projects/B/SharedA/project.pj.
I tried this command:
$ si sharesubproject --sharedProject=/projects/A/project.pj --type=build -rsubproject 1.5 --project=/projects/B/project.pj SharedA
But in this case I'm getting the following error message:
*** MKS978530: This command accepts a selection of exactly one subproject location.
How do I have to modify my command to get the share as described above?
Kind regards,
Christian
awalshAnswer
May 27, 2019 2:58 PM UTC
One more change - the command line does not automatically add project.pj to the subproject name, so you need to have that as well:
si sharesubproject --sharedProject=/projects/A/project.pj --type=build -r 1.5 --project=/projects/B/project.pj SharedA/project.pj
May 27, 2019 1:56 PM UTC
Hi Christian,
It looks like you have a minor mistake with the subproject revision parameter....
-rsubproject should just be -r <revision number>
So the complete command would look like this:
Hope that helps!
-Andrew
awalsh5-Regular MemberAnswer
ChrisIng1-VisitorAuthor
May 27, 2019 8:59 PM UTC
That's it, thanks a lot.
After reading your answer I even recognized, that 'subproject' is italic at the CLI documentation - I guess I should no longer work in the evening.
