Howto Rename Subproject from lower to upper case
by mistake a subproject has been created with a lower case letter "myproject" instead of upper case letter ("Myproject") in the beginning.
So I tried to rename it using the SI-Function "Subproject move" but I get an error message that the project already exists.
Is there any way to do this kind of rename?
Best regards,
Kai
    AlanLewAnswer
    Unfortunately, if the Move Subproject command didn't rename the project then there is no current way to accomplish this without using advanced techniques. There is an RFC posted to the R&D team to resolve this lack of functionality, RFC 109145.
    Please open a new Case with PTC Technical Support to be associated with the above RFC.
    AlanLew5-Regular MemberAnswer
