[IM] "deferred relationship" between items possible?
Hi @all,
today some users came to me and asked me if following would be possible:
We have amongst others two itemtypes in our changemanagement: lib-request and package-request. The lib-request has a relationship-field, which can hold some of the package-requests. The idea was that user a could place a package-request into the relationship-field of the lib-request, but this should be some kind of deferred relationship, and user B has to confirm (or negotiate) this relationship. Is this possible (without a third request)?
Thanks, Jens
    mrumpAnswer
    Hi Jens,
    What about 2 relationship fields in the lib-request (like "proposed Relation" and "accepted Relation") and a kind of "staging/review" workflow?
    Only one of the Fields (proposed Relation) is editable by the users, the other one is read only (except for your scripting accound)
    Write a trigger script that copies the Relatiionship from one field to the other, in case the triggers run conditions are met (e.g. a State change to "confirmed")?
    HTH Matthias
    mrump16-PearlAnswer
    Hi Jens,
    HTH Matthias
    JensN.1-VisitorAuthor
    Hi Matthias,
    thanks for your hint, this looks promising.
    kind regards, Jens
