Im getting JavaScript Error in a IM trigger
I am trying to get the User Object from imUserBean, but I think it cannot be created: JavaScript Error: Internal Error: undefined: Cannot convert null to an object
function main()
    if(delta.isNewlyPosted() && delta.getNewFieldValue("Severity") == null){
        abort(user.getFullName());
var delta = bsf.lookupBean("imIssueDeltaBean");
var eb = bsf.lookupBean("siEnvironmentBean");
var user = bsf.lookupBean("imUserBean");
main();
So I am trying to create the object with bsf.lookupBean and then abort the action with the full name of the user who caused this action.
Instead I get the error in the line (bold).
Thanks in advance
Alexander
    mrumpAnswer
    There is a difference between user beans from the Integrity Manager (Workflow & Documents) and the Domain Users.
    Unfortunately both use a Bean called .....ScriptUserBean
    • mks.si.brain.triggers.beans.ScriptUserBean
    • mks.ci.server.engine.LocalTriggerManager.ScriptUserBean
    I'm not sure with one is returned by
    Nevertheless, every time I tried to solve a task like your's in the past I ended up using the following template:
    //get the Server bean
    var sb = bsf.lookupBean("imServerBean");
    // get the bean representing the current item
    // fetch the user name from the current item's bean e.g.
    var currentUserName = delta.getCurrentUser();
    // retrieve the matching user bean from the server
    var userbean = sb.getUserBean(currentUserName);
    // analyze the user bean
    if( userbean.isMember("a Group") == true ){
      // do something
    HI Alex,
    i assume your user is null, as
    ives you an undefined user bean.
    I'd choose someting like this:
    var user = delta.getCurrentUser();
    or
    var user = delta.getCreatedUser();
    or
    var user = delta.getModifiedUser();
    given your use case, they should all return the same user.
    HTH Matthias
    aharms1-VisitorAuthor
    thank you for your reply.
    Iis not described in my question, but I need furthermore the group of the user, not only his name.
    I want to try something like this:
    if(user.isMember("Some_group")){
         abort("foo");
    I dont understand why this bean is empty or null. Because I use a Domain User who is imported into Workflows&Documents. It must have bean for IM user...
    Any other idea how to get the user and its groups or membership of a specific group?
    Thank you
    mrump16-PearlAnswer
      // do something
