Integrity 2010, how can I tell who is signed on to the system right now?
I believe I found it: Server Diagnostics and then License usage. Thanks.
    dmirkovicAnswer
    Hi Michael,
    License usage will provide the license usage statistics for the Integrity Lifecycle Manager server application. To identify who's currently logged/signed into the system, while in the Administration client, you can expand Server Diagnostics and then use Client Connections, then select the run button.
    Dragan
    dmirkovic12-AmethystAnswer
    Hi Michael,
    Dragan
    You can also use CLI command si diag --diag=licenses which will give you the license statistics.
