Sep 24, 2018 3:39 PM UTC
Integrity Command Line Timeentries
Using the Integrity CLI to extract time entries for analysis and processing.
I use something like this;
im timeentries --hostname=host --port=port --filter=user:username --filter=entrydata:"between START and END"
(note don't type this in by hand, I have wrapper code written in Python.
I also use mksapiviewer.exe to process the command output as XML and parse it. This all works nicely).
The above example extracts the time entries for a user user between the dates START and END. I now have a user case where I would like to extract all time entries recorded against a given Issue ID in a specific time range, regardless of which user entered them.
Looking at the help
im timeentries --usage
I see there is a sub-option in the filter section
issue=<expression>
However, I am not sure what 'expression' means.
I have tried the obvious approach..
im timeentries --hostname=host --port=port --filter=issue:ISSUEID --filter:entrydate:"between START and END"
but  I get the following error in my XML:
<Message>MKS124814: Cannot show view information: You must specify an operator for numeric</Message>
It is not obvious to me what the above error is referring to, and what exactly "specify an operator for numeric" means.
Any help would be appreciated.
thanks,
will
awalshAnswer
Sep 26, 2018 3:53 PM UTC
For the issue filter, the expression is a single issue or range of issues. For a single issue, you need to use = before the item ID.  The CLI reference says you should be able to use AND within the filter, but I found that didn't work.
Instead I used the same method as for si filter options:
"Using commas between the filteroptions serves to build logical "OR" statements between them, allowing you to create powerful filters. You may also specify multiple --filter=filteroptions on the command line, which effectively creates logical "AND" statements between them."
For example:
D:/private/IntegrityServers/12.0>im timeentries --filter=issue:=652
652 ascea 24-Sep-2018 MKS Integrity 3
652 ascea 23-Sep-2018 MKS Integrity 2
D:/private/IntegrityServers/12.0>im timeentries --filter=issue:"> 1000"
40922 ascea 27-Sep-2018 MKS Integrity 2
40927 ascea 26-Sep-2018 MKS Integrity 12
40784 ascea 25-Sep-2018 MKS Integrity 2
D:/private/IntegrityServers/12.0>im timeentries --filter=issue:"> 1000" --filter=issue:"< 40920"
D:/private/IntegrityServers/12.0>im timeentries --filter=issue:"> 1000" --filter=issue:=652
D:/private/IntegrityServers/12.0>im timeentries --filter=issue:"> 1000",issue:=652
I hope this helps.
awalsh5-Regular MemberAnswer
For example:
I hope this helps.
wstokes1-VisitorAuthor
Sep 27, 2018 9:04 AM UTC
OK, so using just the numeric value
filter=issue:123
does not constitute an "expression", whereas;
filter=issue:=123
does. I guess that makes sense, although I have to admit its a little un-intuitive.
However the solution works like a charm so many thanks.
have a great day
will
