Integrity javascript invoke powershell script is that reasonably possible?
Would like to invoke/call from a Integrity Server Java script a powershell script.
  • The process would take an email address from inside an Integrity Java script and call out to a powershell script
  • The powershell would extract user log in id from Active Directory based upon their email address that was passed in to it.
  • The powershell would pass back the user log in id to the calling Integrity java script.
Similar to how getUserBean( ) lookupbean instead using email address would be a great option
Although I have already run PowerShell out of Java classes, I'm not sure if this approach is also valid for JavaScript.
I'm assuming that you want to run a trigger, right?
Within the trigger, you can execute server-side Java code or custom Java code.
Would it be an option for you to run Java instead of Powershell?
Volker
jsummers1-VisitorAuthor
Yes that would work just wanting to extract the user information based upon their email address from LDAP if possible
