Oct 9, 2019 8:16 AM UTC
Integrity Lifecycle Manager 12.1. Java API cannot fetch requirement with image.
It is not possible to fetch an item containing an image with the Java API. A com.mks.api.response.CommandException: mks.frame.app.ui.ViewException is thrown.
Fetching is done by exectuting a viewissue query with the cmdRunner. I use API Version 4.16.2671.
Did anyone experience a similar problem?
Oct 11, 2019 5:00 PM UTC
Hey cpellegrini,
It looks like you have a Support case open for this too, already, so hopefully they get this sorted with you.
What is the rest of the ViewException error/stack?  Any other info shown there?  That may be helpful.
Oct 14, 2019 2:34 PM UTC
Hey,
Yes I opened a support case as I wasn't sure where is the right place for this question. But so far the problem isn't solved.
Interesting to know might be that the error includes a field exception-name with value "common.ViewFailed" and a response containing parameters of the workitem we are trying to fetch.
I do not have a stacktrace with additional information.
