INtegrity merge question
Is there a command that checks whether or not a member is merged to a specific branch ?
I don't believe what you're asking exists, but I think more information is needed to fully understand your question.
Are you talking about a merge/inheritance feature?
What do you mean by "branch"? (I really, really hope it's not the old branched model technique!)
hmagnanao1-VisitorAuthor
I'm looking at a file in branch A. I want to know if it was merged correctly to branch B. I know how to look at member history to find it out but I want to know if there is a command that can check.
Are you talking about Integrity or Creo?
Integrity
Hello Hector,
I assume you are using change packages? If so, then through the GUI you could look for change packages that contain the member, and see which branches that member is part of.
Kael
Yes, we are using change packages. But, I am looking for a command line version to check if a member is merged to a branch.
Hector
Hi Kael,
I know how to check it through the GUI. I'm looking to script this using a command line interface in Integrity.
