IRC and DOORS issue "The Doors database path 'xxx' for the document SEPC_XXX' does not exist"
I have a problem with a DOORS (9.6) module that I am trying to update via IRC (3.4). I have a module named SPEC_A that was imported in DOORS baseline 1.0 using a ReqIF file with IRC. This module was later renamed SPEC_B, evolved, and moved to DOORS baseline 2.0. Since baseline 1 was a DRAFT version, I deleted the initially imported module,
thinking that since it has changed its name, IRC would consider it as a new module and therefore perform an “insert.” However, when I tried importing the new module with the changed name (SPEC_B) via IRC, IRC tells me that SPEC_A does not exist…
I try to restor a SPEC_A to import a .dma in the tagert path in order to have a correct target on the path of IRC but I think that the importation of the dma haven't the same id hat the original SPEC_A module and IRC and IRC no longer recognizes the module SPEC_A...
Do you have any solutions?
I thought that IRC would understand that changing the module’s name would be considered as a new module (and therefore treat it as an insert), but that is not the case...
Catalina
Community Manager
Hi @RL_13916218
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
