6-Contributor
Is it possible to edit group name that once created in MKS Domain Groups with Integrity admin client?Thanks in advance.
    It's hard to understand why, but you cannot rename an MKS Domain group.
    You have to create a new group with the new name and then assign all the group members.
    If the group is used in Workflows and Documents (all groups don't have to be, some can be CM-only), you should rename it there and it will pick up members from the new MKS Domain group (you won't have to redo all your permissions and rules if used).
    As almost anything in Integrity is stored in the database it is technical possible to edit the groups table directly in the db.
    We did that in the past, but as far as I know it is not recommended by PTC support.
    Nevertheless you should post this as an improvement in the idea section.
