Is it possible to run script from a c# application?
Nowaday, I build c# UI and application to answer to designer's needs.
In order to keep our application as independant as possible, i would like to run scripts contained into a given model from those application.
Do any elements exist to do so?
    sdumonAnswer
    Hi Kael,
    Sorry for the delay.
    I finally found a solution wich maybe could help the comunity. This solution is not as simple as I expected but works fine.
    This is what i have done :
    1. get the script object present in your model (A), especially the script text.
    2. concat the script text with the following script (B)
    Dim CurrentObject, Dictionary
    Sub Main()
      On Error Resume Next
      Set Studio = CreateObject("Studio.Editor")
      Set Projects = CreateObject("OMTE.Projects")
      if Err.Number > 0 then
      Studio.DisplayOutputWindowMessage Err.Description & " " & Err.Source & vbcrlf
      Err.Clear
      end if
      Call Studio.OpenModel("%_PROJ_NAME_%")
      modRef = Studio.GetCurrentModelReference()
      Set Project = Projects.Item("Reference", modRef)
      Set CurrentObject = Project.ItemByID("%_PKG_ID_%")
      Set Dictionary = CurrentObject.Item("Dictionary")
      Err.Clear
      else
      if RunUtilityUI then
      Project("Transaction") = "Begin"
      CommitUtility
      Project("Transaction") = "Abort"
      else
      Project("Transaction") = "Commit"
      end if
      end if
      end if
    End Sub
    Call Main()
         This script open the model in wich the modification should be done, call the utilityUI method of the retreive script text.
    3. Once the concatenation is done, save it into a temporary vbscript file.
    4. Create a process wich execute the CSCript exe, and execute the temporary script previously created.
    5. Finally, observe the modifications.
    This method is a complex one but allow to execute a given script from outside of a model.
    Hope this could help.
    Regards
    Hello Stephane Dumon‌,
    I don't have a direct answer for your question, but I'm wondering if this information might be helpful?:
    Which release of Integrity are you using?
    Kind Regards,
    Kael
    sdumon1-VisitorAuthorAnswer
    Hi Kael,
    Sub Main()
      Err.Clear
      end if
      Err.Clear
      else
      CommitUtility
      else
      end if
      end if
      end if
    End Sub
    Call Main()
    Regards
