Is there a possibility to automatically teach PTC Integrity client to selective resync only a few subprojects from a sandbox?
I have a sandbox with multiple subprojects. I want to automatically re synchronize only a group of selected subprojects. Is there a possibility to do this?
    Hello Gabriel,
    There is no mechanism to automatically refresh a sandbox or portion of a sandbox, though the sandbox does change the file decorators to notify you if there are newer revisions on the server. Given these visual notifiers, you can selectively resync a subproject by selecting it and pressing 'F6' or selecting Resynchronize from the Member menu.
    If you have a sandbox which will not change often, you could create a script to resynchronize a given subproject within it using CLI commands:
    si resync --sandbox=C:\Sandbox\or\subsandbox\location\project.pj --norecurse
    The above command will resync only that project location. If you wish to resync recursively you can use --recurse instead. For more options with the si resync command, type 'si resync --usage'.
    Hello Gabriel,
    Hi Joe.
    Thanks for your answer. This is what I did and I have created a batch file with multiple resync commands for the respective subprojects. I was wondering if there is a more elegant solution.
    All the best,
    Gabriel
