7-Bedrock
Is there a way to maintain the order in which the items were inserted into a relationship field in a chronological order?
The Order column is not helping me here.
    Hello Ritu Raj‌,
    In Integrity Lifecycle Manager 10.6 this is already the case.  If you add a relationship in the GUI, by default it will add that relationship to the end of the existing relationship set.  If you add from the command line using im editissue --addfieldvalues=<RelationshipName>=<ItemIDToRelate> <ThisItemID> it again appends the related item to the end of the list of items in the relationship list.
    Does that help, or do you need additional information?
    Kael
