Java Code
How to run java code from GUI.
    a little bit more context would be nice
    How to customize user buttons to run a Java code.
    What is Environment file and How to set the parameter for Environment file.
    Hello A.A.,
    I can interpret this two ways:
    1. You would like to customize the behavior of built-in Integrity buttons: You can't, really, although there are a limited number of client side triggers that might be helpful.
    2. Activate custom buttons: This is possible, and there are context dependent environment variables that are available. The only documentation I could find in a quick search was this:
    If you could clarify this further, I can see if there is any further information that I can dig up for you.
    Kael
