java.SQL.Exception - not full-text indexed
I've successfully installed Integrity Server 10.3 with SQL Server 2008 R2. The server runs but in the server.log file, there is the following exception:
ERROR [mksis.IntegrityServer] * * * * ERROR * * * * (0): java.sql.SQLException -- java.sql.SQLException: Cannot use a CONTAINS or FREETEXT predicate on table or indexed view 'Text3' because it is not full-text indexed.
I searched a by the Integrity documentation avec DB requirements and settings, but found nothing related to full-text indexing. This is not also a feature or setting of SQL Server.
Could someone tell me a bit more about this exception? How to fix it?
Thanks.
You are seeing this error because you don't have the correct database priviledges granted to the Integrity database user. The database user needs the db_owner role. This is outlined in the Installation guide.
To remedy this, give the Integrity database user the correct permissions, make sure you have case-sensitive collation installed on the database and enable Full Text Search.
isodius12-AmethystAuthor
Thanks Jeremy,
I won't be able to test your advice until this next monday. But I'll do asap.
Thanks again for the help.
