Mar 28, 2017 8:50 AM UTC
Locate members existing in a subproject and all its child subprojects
We are using Integrity Client version 10.8.0.8356
My project has a hierarchical structure of subprojects containing file members and other subprojects
+project.pj
  +Documentation\project.pj
  - Release\project.pj
     - src\project.pj
         - core\project.pj
               member1.java
               member2.doc
         - tests\project.pj
                TestCase1.java
                TestCase2.java
I would  like to be able to search (locate) file members existing in the src subproject and all its child subprojects (i.e. core and tests)
Unfortunately the si locate command does not seem to allow searching by starting from a selected subproject (i.e. src) in a recursive manner
I use the si locate command according to the SourceCLIReference_Integrity_10_6.pdf documentation
a) If I use --projectscope=this option , then only the immediate children members of the src subproject are found, no downwards recursive search appears to be performed in contained subprojects
si locate --hostname=someServer --port=somePort --user=someUser --project=t:/..../src/project.pj  --depth=current   --noexactmatch  --nocasesensitive  --projectscope=this --memberbyname=member1
b) If I use the  --projectscope=all option, then all the registered projects on the server are searched, which is not what I want, sorry. There are far too many projects on the server to search in all of them.
si locate --hostname=someServer --port=somePort --user=someUser --project=t:/..../src/project.pj  --depth=current   --noexactmatch  --nocasesensitive  --projectscope=all --memberbyname=member1
Any help is welcome, thank you!
    llambertAnswer
    Mar 28, 2017 8:10 PM UTC
    Hi Alexandru,
    I cannot help you with core functionality but i have a custom written search tool that can be plugged into the client as a custom action and it will work through subprojects.  Let me know if you want this tool.  Again, it was built by PTC field team so is not maintained by PTC support but still works across many versions of ILM.
    llambert12-AmethystAnswer
    Hi Alexandru,
    amatei13-AquamarineAuthor
    Mar 29, 2017 6:33 AM UTC
    Hello Lance,
    Yes, certainly it would be very helpful to see how it works, thank you.
    How can I have access to the tool ?
    Mar 30, 2017 7:40 AM UTC
    I dont know if that helps but
    The only method I found generating some kind of parseable project tree (with 10.4) was something like
    si viewproject -R -P D:/project/on/server/project.pj --projectRevision=1.3 --filter=file:NO_MATCH
    I would also be interrested in a command/method to output the project and all the subprojects within
    the tree as a list of absolute server paths.
    Anyhow form the performance aspect it might be better for you to filter/parse the results
    of 'si locate --projectscope=all'.
    HTH Jürgen
