Login through CLI command
Good morning
I am just wondering if it is possible to login from CLI command? The reason I ask is I have to import data through PTC integrity and into a web based application so if I can login from client computer it can import data for anybody that is using the web application.
Thank you for the help
    tketzAnswer
    Hey Muhammad,
    for every CLI Command you found some help with --? or in the CLI Reference Guide.
    you need that:
    si/im connect --hostname=HOST --port=PORT --user=USERNAME --password=PASSWORD
    yes you can:
    si connect
    or
    im connect
    mkhan-21-VisitorAuthor
    Thank you. I can see how can I use my password but is there anyway I can use a username as well. The reason for this is the program will be running on the web and each time user uses to run MKS need to connect.
    tketz1-VisitorAnswer
    Hey Muhammad,
    you need that:
