Looking for script example for parsing response of Java API.
I'm hoping that this has been done 1000's of times and someone has an example to share.
I need to parse the response from a JavaAPI call from a trigger script.
Example:
var cmd = new Packages.com.mks.api.Command("im","issues");
cmd.addOption(new Packages.com.mks.api.Option("queryDefinition", queryDefinition));
var response = api.executeCmdAs(currentUser, cmd);
    Hi Sean,
    Here's a snippet that shows the general concept.
    The JAVA API is used identically in a trigger script, as it would be used in POJ application.
    HTH Matthias
    * creates the Command to Run the temporary Query
    * @return Packages.com.mks.api.Command queryCommand
    function getRunQueryCommand()
    var queryCommand = new Packages.com.mks.api.Command(Packages.com.mks.api.Command.IM, "issues");
    queryCommand.addOption(new Packages.com.mks.api.Option("fields", "Type,ID"));
    var queryBuf = new java.util.StringBuffer();
    queryBuf.append('(');
    queryBuf.append("field[");
    queryBuf.append(singletonField);
    queryBuf.append("]=");
    queryBuf.append(currentValue);
    queryBuf.append('"');
    queryBuf.append(')');
    queryCommand.addOption(new Packages.com.mks.api.Option("queryDefinition", queryBuf.toString()));
    return queryCommand;
    * check whether the temp query finds at least one Item of the same Type as the current Item
    * @return true if successful; false in the event of a failure
    function check4Singleton()
    // Create an API Object to run IM Command Line commands
    var api = environmentBean.createAPISessionBean();
    // Execute the Query command
    var runQueryOut = api.executeCmd(getRunQueryCommand());
    if( runQueryOut.getExitCode() == 0 ){
    logDebug("Successfully run temporary Query");
    // analyse result
    if (runQueryOut.getWorkItemListSize() == 0 ){
    logDebug("nothing found");
    return true;
    else{
    var iter = runQueryOut.getWorkItems()
    while (iter.hasNext()) {
    var workitem = iter.next()
    var tempID = workitem.getField("ID").getValueAsString()
    // add your own code here
    return true;
    else{
    print("Failed to run temporary Query");
    logDebug("leave check4Singleton()");
    return false;
    Hi Matthias,
    Thank you for the quick reply. I'll check this out as soon as I can (like early next week). I've been handed a set of higher-priority tasks to tackle.
    Best of thoughts...
    -Sean
