11-Garnet
Oct 25, 2017 1:54 PM UTC
Mail trigger
Dear PTC-Community,
we have currently faced the problem with Mail-Trigger function implementation. We cannot find any proper solution on how to integrate the Mail-Trigger function into PTC.
Any advices would be much appreciated!
Best regards,
Daniel Remmers.
apawarAnswer
Nov 1, 2017 3:33 PM UTC
Hello Daniel,
there two steps to taken care of here to set email triggers:
  • To configure correct mail server properties
  • Make sure to setup correct trigger logic
Here is the article for more information:
Moreover, it needs more clear details of the issue to understand the cause.
Amit
Oct 26, 2017 11:33 AM UTC
Daniel,
Could you provide some more information, such as a use case.
Dan
apawar5-Regular MemberAnswer
Hello Daniel,
Amit
dremmers11-GarnetAuthor
11-Garnet
Mar 26, 2018 3:07 PM UTC
Thank you! The manual helped.
solution in short (out of my head):
Admin client node "Workflow & Documents" >> Triggers >> adapting js-file >> setting trigger rules
Admin client node "Configuration" >> mksis.mailserver >> entering the correct data of your companies mail server
Nov 14, 2019 1:37 PM UTC
uld You please share the steps to enable the smtp configuration with sendgrid?
We are getting error as "unauthenticates senders are not allowed"
