Mandatory Field for specific Group (not state transistion)
Is there a way to make a field mandatory for a specific group? We are using MKS Integrity 2009 SP5. I now we need to update it with the latest SP.
I have a work flow that after intial input the state is set to 'Ownership ID'. An email notification is sent to 5 different groups. Each of the groups has custom fields for their group. Each group has a custom integer and Longtext field that they must provide input to (I.E. the mandatory fields). The state does not change until all 5 groups have provided thier input. How can I do this?
    Daniel,
    There are two answers for your question.
    First, starting in Integrity 10.1, we introduced a new constraints system that would make this much easier to do as it give a lot more flexability over options such as this.
    In earlier versions, however, the best way to do this would be to use a pre-trigger to check the field and the user group and either stop the submit or let it pass based on the rules you put in the script.
    DanR.1-VisitorAuthor
    pre-trigger? Which trigger? We're not using version 10, we use 2009. I'm not a script expert, so we have been using the out-of-the-box scripts with minor modification.
    Unfortunately, there is not an out of the box trigger for this. It is not a complicated trigger, but it would have to be written specifically for this situation either by your team or our services team.
    Hi Daniel,
    reading all the answeres above I think they missunderstood your intentions. As as far as I get it:
    - you have an item in "initial" state and you you want to start a workflow that collects input from 5 different groups of users by transfering it into "Ownership ID" state. correct?
    While the item is "waiting" for it's state transition:
    - each group has it's own set of mandatory fields and
    - only if all fields from all groups are filled, the the state transition from "initial" to "Ownnership ID" is completed. Correct?
    Please answer if I am rigth, because help is possible 😉
    even in 2009
    You are kind of right. Each group has fields we would 'like' to be mandatory, but because it only works with state transition we cannot do it. I understand that a script would work, but I do not know where to start. The MKS... err PTC documentation is to generic and does not explain things well. Is this the price we must pay for a tool that is highly customizable? Yet that could be it's downfall.
    Hi Daniel,
    there are some facts:
    - in Integrity prior version 10.1 you cannot change the "mandatoryness" of fields dynamically. A field can only be mandatory for a state change.
    - the Trigger api is quite generic and you can get almost all the information you need, but only if you know where to look.
    Nevertheless, as far as I understand your use case, here's what I would do:
    Assuming the info you request from the 5 groups is some kind
    sequential you could create 5 states ("requesting info from group x") and allow the transition only for the appropriate group. You set the mandatoryness of the according fields for each state separately.
    Assuming there is no "order" in the groups and you want to be more flexible, I would create only one extra state "collect data" and the transition from "collect data" to "ownership ID" would only be allowed for the admin group.
    Then I would set up the fields (e.g. 3 fields per group) in a way thy each group member in question could only edit it's own group's fields.
    Then I would write a trigger (maybe scheduled daily) "autoPromoteItemState" that uses a query "all item in state 'collect data'". This trigger checks whether all fields are filled out and if so it changes the Items state to "ownership ID".
    All you need for a trigger like this, you can find in the sample part of you installation
    For the scheduled trigger you need something like this:
    // Main execution block...
    function main()
    // get the items defined by the trigger's query
    var issues = args.getIssues();
    for (var i = 0; i < issues.length; i++) {
    // get a "writeable" bean for each item
    var itemDeltaBean = serverBean.getIssueDeltaBean(issues[i]);
    //check the items content
    if(allMandatoyFieldsFilled == true){
    itemDeltaBean.setState("my new state");
    var environmentBean = bsf.lookupBean('siEnvironmentBean');
    var serverBean = bsf.lookupBean("imServerBean");
    var params = bsf.lookupBean("parametersBean");
    var args = bsf.lookupBean("imScheduleTriggerArgumentsBean");
    HTH
    Matthias
    Remains unresolved.
    Daniel,
    I think this issue needs more attention than the community set up can provide. I would like to ask you to open a support case so that an engineer can properly research and walk through this with you.
    You can open a case with our support team here:
    https://www.ptc.com/appserver/cs/case/case_logger.jsp
