Matlab synchronization with Integrity LM
After setting everything correctly as written in the documents and opening the Matlab and LM client as admin, when I try to synchronize my simulink model with Integrity LM, I get the following error:
DEBUG: Integrity Lifecycle Manager Solution Type is required.
and when I again click 'synchronize Model', then following error appears:
DEBUG: MKS157416: MKS157416 No valid types for prefix "model.mathworks" and type property "model.mathworks.type" set to true.
Command cancelled by user.
Could any expert help me on this issue?
Within Integrity administration, do you have a Type named "MKS Solution" their?
Adeeljsid1-VisitorAuthor
Hi Veckardt,
No, I don't have the Type named ' MKS Solution'. How can I add that? In the Matlab Integration tutorial on the PTC university, He didn't instructed to do it.
Thanks for your reply!
Hm, ok.
Next Question: Do you have the following types present?
- Model
- Model Element
- Shared Model Element
- (optional) Simulation?
If not, whats your ALM Configuration based on? Was it hand made or is this based on any known PTC Solution template, such as ALM Template, SysEng Template etc.?
