3-Newcomer
Oct 12, 2026 11:14 AM UTC
Member revision update fails after check in
I am using PTC RV&S (formerly Integrity Lifecycle Manager) Release 13.0 and Datecode13.0.0.6 Item modified, changes are recognized via Visual Diff, but member revision not updated on checkin. No immedate error message. Member drop, readd as new archive, same behavior, error message below. Added another test file in same repo, check in/out worked correctly in the same sandbox. Here are the errors that I faced Operation = add State = Failed SIArchiveTreeExistsException: MKS995055: An archive ".../Veracrypt.ps1" already exists
Catalina
Community Moderator
Oct 20, 2026 8:39 AM UTC
Hi ​@asvoboda
Thank you for your post. 
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Catalina | PTC Community Moderator
