Jul 13, 2020 9:14 AM UTC
Missing IntegrityExportProperties.properties file
Dears,
I am exporting documents into word. In the Gateway.log I get the following message:
WARNING: C:\Program Files (x86)\Integrity\ILMClient11\lib\patch\classes\IntegrityExportProperties.properties (The system cannot find the file specified)
Where can I find the IntegrityExportProperties.properties file?
Leandro
Jul 13, 2020 12:59 PM UTC
Given the message and location, it seems to be a file that's installed with the client.
You may want to reinstall the client or check if there is a Critical Service Patch for this (seems unlikely to me).
The quickest way to deal with that is to open a case with PTC Support.
Jul 31, 2020 11:32 AM UTC
The file you are looking for is one of my own export solutions for Word and/or Excel. Internal name is CustomGateway.
The message is a warning only. The functionality is not affected. You only need this file if you want to overwrite specific default values, which is not that often needed.
Does this help?
Aug 3, 2020 8:55 AM UTC
Thanks for the info.
Could you provide me this file with the available options? Can you provide a document explaining the properties available? Where should I place it?
Thanks for your help!
Leandro
