MKS 124822 reports change outputpath
how can i change the settings for outputfile-path:
my messages :
2014-03-04 11:42:41,668 INFO [STDOUT] Error executing API in creating Monitoring-Report - Message: mks.frame.triggers.TriggerAPIException: [API-runreport]: im: MKS124822: Invalid value provided for "outputFile": File paths must be rooted in C:\Program Files\Integrity\IntegrityServer10\data\tmp: outputFile is set to D:\REPORTS\Monitoring\MON-Report_2014-03-4.csv
What is wrong?
thanks for responses
br
M. Hiersche
    Hello Martin,
    From the diagnostics you have supplied, I suspect the issue is that you are directing the output of the trigger to a location that is not a subdirectory of C:\Program Files\Integrity\IntegrityServer10\data\tmp.
