mks124811
Any thoughts on what is causing this error::
MKS124804: Internal Error detected: Error Was: mks.frame.app.model.ReadOnlySettingException:MKS124811:INTERNAL ERROR: Attempt to set read only setting: lockType: Locked by the server
THANKS...!
    Hi Joe,
    Do you have anymore context for this issue, and the error?  Given the error, I'm suspecting you are getting this error in relation to sandboxes, and Configuration Management policies/conflict?
    jmraz1-VisitorAuthor
    Hi Michael,
    It turns out this was the result of a failed merge attempt.  User ultimately wanted to make the branch tip the root tip.  Had them lock the root, check in the branch, and respond to warning messages accordingly.
    I think we’re good…….thanks for the follow up…!
