MKSSI command for viewing Subproject config path.
I am aware that MKSSI_PROJECT_CONFIG_PATH command displays the project configuration path.
If i had to display the configuration path of a subproject then what would be the command?
I would like to know if the below understanding is correct:
MKSSI_SUBPROJECT" + cnt + "_CONFIG_PATH when a normal subproject is configured as Build.
Due to the above command MKSSI_BUILD environment variable value is not getting set.
    Hello Karthik Komarla‌,
    Interesting!  What kind of environment is this command available in?  Could you provide some sample output?
    Kael
    Hi Kael, you can see the environment variables the Integrity Client has available by creating a custom button which runs "cmd.exe". That will pop-up a CLI window and you can run the "set" command to view all the variables available.
    Karthik, you can also get the config path of a project/subproject by running si projectinfo --project=/MyProject/project.pj
    You could also get creative and cut out everything but the Config Path: si projectinfo --project=/MyProject/project.pj | findstr "Configuration Path:"
    Thanks Joe Bartlett‌,
    I missed that this was from the context of a custom button.
    -Kael
