Modeler: Change line styles?
How can I change line styles for link items in PTC Integrity Modeler?
1) For example, I would like the link lines to run in a rectangular fashion (i.e. parallel to grid lines instead of across), but I can't seem to find the button/option where to set this.
2) How can I force links to collapse? This applies for nesting links for example, I'd prefer a design that resembles an file structure rather that a few separate links.
Thank you!
Lisa Moevius
Dear Lisa,
  1. The answer of your first question is not that easy. There is no button to change the pathway of links. One solution is to set Waypoints for all links by hand. Another solution is probably to use the automation interface of the Modeler. This would be a customization and is not easily done.
  2. If I understood your second question correctly. The solution is following:
    1. right click one link
    2. click “Align [e.g. Aggregation]”
I hope I could help.
Nico
