Monitoring a SourceTrace change by trigger
- 1 reply
- 2184 views
- Translate All
Hi all,
I'm looking for a way to close a current gap in the I10.2 implementation.
I have a node item type (requirement) that contains a SourceTrace Field (a "trace" not a "link" - meaning that any update to the memberrevision of the trace will be propagated to the Item). This in general works fine.
What I'd like to have chance to "react" on these updates by
1. flagging the node item as suspect
2. sending an e-mail to the stakeholders
Unfortunately the Update is done by some "background magic" and therefore no event is fired during the update of the item.
As a result I cannot use a IM trigger based on the usual :
compare: field (old value)<>field (new value)
schema.
As a second though i tried a differnt approach: I wrote a SI triggerscript (see attachment ) that uses the IM "viewsourcetraces" command to get all referenced Items for this member and i then i can process these IDs.
I started with a POST trigger, but in that case, the trigger was fired a a moment when the member revision was already changed, but the source trace was not updated yet, so the "viewsourcetraces" command always resulted in a empty list.
So i used a pre trigger as I need both the OLD revision of the member, to get the traced Items.
This works fine, for the e-mail submission, as a readonly IssueBean is no problem.
But if try to open the Items for performing a significant edit (e.g. add a comment that would trigger the suspect flagging), I cannot get the IssueDeltaBean from the server.
Anybody any ideas?
