MS Project mapping with Work Items and Change Orders?
With the Microsoft Project Integration we are able to map Work Items from Integrity into MS Project.
Is it possible to map Change Orders from Integrity to MS Project?
We want to have both types in MS Project - the Work Item and the Change Order.
Does anyone have an idea how to solve the problem?
Thank you very much.
Florian
    Hello Florian,
    You might want to take a look at case solution CS135976: How to use the Integrity Microsoft Project Integration without ALM. This article does not directly discuss what you are doing, but does go into the details of modifying Integrity items to work with the MS Project templates, and may give you an idea of where to proceed.
    Failing that, you may with to open a case with the PTC Integrity Technical Support team, and share what you learn with us.
    Does anyone else have any ideas about how to approach this issue?
    Kael
