Aug 1, 2020 7:59 AM UTC
"No instance properties file was specified" error when launching the Integrity Client
When I launch the Integrity Client 11.2 I see a message box: No instance properties file was specified
Please write the solution here because I do not have access to this protected content
https://www.ptc.com/en/support/article/CS90066
Please also see the attached file.
LLawtonAnswer
Aug 1, 2020 12:36 PM UTC
What the article says is that the wrong executable is used to launch Integrity.
Check the shortcut you use to launch the client and make sure the program is "integrityg.exe", and not "IntegrityClient.exe".
I've seen that error when people try to create their own Windows shortcuts/icons and don't know to use "integrityg" which is not the obvious choice. Sometimes I wonder if PTC loves the old French saying: "why make things simple when you can make them complicated?"
LLawton16-PearlAnswer
