Apr 1, 2016 8:47 AM UTC
Open the Project view in Integrity Client GUI with a file member highlighted ?
We are using Integrity 10.8
Is there a trick to open the Project view in Integrity Client GUI with entire project content visible and just one file member highlighted in the tree ?
Currently it seems that this is not possible, by using the URL below, just one file member is displayed and everything else is hidden.
integrity://server:port/si/viewproject?project=ProjectPath&selection=FileMemberName
I want all the project content visible, just highlight one of the file members. Please see the attached image for an example.
    tdalonAnswer
    Apr 1, 2016 11:04 AM UTC
    Hi
    This is not possible:
    see also Open file in sandbox view via CLI with file selected
    PTC will probably answer you can make a RFC for this feature.
    Thierry
    tdalon1-VisitorAnswer
    Hi
    Thierry
    Sep 9, 2020 4:00 PM UTC
    Unfortunately it is still a problem. 11.1.0.961
    But.
    You can use:
    1.) I used this. Unfortunately it is not possible to let display the history up to a defined memberversion
    integrity://integrity_server:PORT/si/viewhistory?selection="my file name.xy"&project=/Project_path/project.pj
    2a.) I liked better but not used:
    2b.) It become fast my favorite:
    integrity://integrity_server:PORT/si/viewhistory?selection="my file name.xy"&projectrevision=x.y&project=/Project_path/project.pj
    // you have to know in which version of the project existed your needed member 🙂 did not worked by me correctly
    PTC PLS: implement the si/viewrevision, what would be great thx.
