Problem tracing shared requirements
Hi all,
I am trying to do some trace analysis using a Python script that queries MKS using im commands. I'm running into some weirdness (probably from my lack of understanding) on some IDs. We have a top level Requirements document with three subordinate Requirements documents. Some of the text from the top level document is shared to the three lower level docs and one of the shared requirements is where I'm having the problem
I've shown the structure with some of the "im viewissue XXXX" data for the docs below. My problem is that the last one, 464438, shows four downstream traced documents ("Satisfied By") in the GUI but nothing from "im viewissue 464438". How do I get these "Satisfied By" links?
Eric
25715
References: 82318xyz
Reference Mode: Author
Referenced Item Type: Shared Requirement
Shared By: 89425, 148417, 189358, 464438
Satisfied By:
Decomposes To: 189358, 148417, 464438
Trace Status: downstream
189358
Reference Mode: Share
Satisfied By: 118905, 442438
Decomposed From: 25715
Trace Status: upstream downstream
Shared By:
148417
Shared By:
464438
Satisfied By:
Shared By:
Eric1Answer
We refreshed our sandbox copy of our database and now it is working properly. I'm confident that there was a problem of some sort since the program I'm writing stumbled on it and I confirmed by manually sending the commands. But since I can't replicate the problem I'll close the question (but feel free to comment if it rings a bell for anyone).
Eric
Eric11-VisitorAuthorAnswer
Eric
Eric,
If you do manage to reproduce this, please contact Integrity Support, so that we can attempt to diagnose the problem and resolve any defects.
Kael Lizak
Technical Support Engineer
