PTC Implementer 10.3 constraints asp error with dist-move
I have a production issue!
Trying to move a table that has been changed, it also have unaffected constraints to another table that has not changed.
When I use implementer to dist-move the table with constraints it errors on the move portion not the distribution part. The error is 2 - The auxiliary storage pool (ASP) 33 for file {filename} in library IMB... is not the same as ASP 1, which is the ASP of the file owning the format.
I cannot move the table to its final location ...this is BAD.
I already have tables in production with constraints, this may be my first table change moving to production with a constraint.
AGAIN the constraint is not changed it is getting new fields that do not have anything to do with the constraints.
Help anyone?
Hi Scott,
Can you log a case for this issue and attach the remote joblog?
There's not a fast/easy answer to this without investigating.
Thanks!
Dawn
sdamery1-VisitorAuthor
Do you have a link of where I LOG A CASE?
http://www.ptc.com/support/ Click Log a New Case under the Contact Support tab.
