PTC Integrity Configuration Report
I recall there was a way to produce a report that would show all the type design and linkages to other objects.  How do you run  that report?  Thanks,
Rob
Hello Rob,
you may ask for IntegrityDocs, one of the long available generators for html pages with Integrity Configuration details.
If you are interested, just drop me an email.
Volker
(Hint: there are some alternatives available, like the Excel version of it - quite interesting when you plan to make changes and like to track / record them beforehand)
Hi Rob and Volker, I am trying to Resolve this Issue for the Customer. There is way to customize the Trace Reports using ReportEngine.jar file and Custom XMl Template file with all the Fields and Relationships to be passed on using the GUI options. I am trying to Understand and customise the XML Trace Template for the customer.
Hello Laxman,
just to position your request correctly:
The Trace Report as such is NOT a configuration report. My understanding is that the Trace Report allows you to export Document relationships (traces) with further details from the related nodes. On the other hand, a Configuration Report allows you to export information you can see in the Integrity Administrator Client.
Nevertheless, I am not sure how we can help you exactly. Can you please tell us a bit more what functionality you like to get explained?
Volker
Thank you for all the help.  I think this is the document we're looking for and will ask the Admin's to run this for us.
