Apr 12, 2017 5:47 AM UTC
PTC Integrity Plugin Jenkins - project.pj missing
if I checkout a project using the PTC Integrity Plugin whithin our Jenkins everthig is fine, but the projects.pj files are missing. What have I done wrong?
Thank you in advance.
Sebastian
    Apr 12, 2017 1:55 PM UTC
    Hello Sebastian,
    A plain vanilla Integrity Jenkins configuration should checkout everything under a project, unless the "Exclude List" option in the job configuration explicitly specifies .pj to be omitted (or vice versa, the "Include List" specifies only certain file types to be checked out). I presume this is an Integrity Server version below 10.8? Can you specify the ILM version and the Jenkins plugin version.
    Also, what is the use case for populating the workspace with project.pj files? They ordinarily wouldn't be required by Jenkins for any build activities.
    Nov 28, 2018 4:05 PM UTC
    I Have the same issue.
    Project.pj is used to resynchronize the change package or is there another option to do this with The PTC Integrity jenkins plugin.
    Regards
