PTC Requirements Validation & Source 13.5 has Released!
Hello Customers -
PTC Requirements Validation & Source 13.5 has been released and should start showing up on the download location for you to try out and use in the next 48 hours.
The PTC RV&S 13.5 release delivers major value through modernized OIDC‑based security and Codebeamer integration with PTC - SCM [PTC RV&S].
OIDC Phase II strengthens enterprise authentication by supporting leading identity providers (PingFederate, Okta, Entra ID), improving security posture while simplifying compliance and long‑term operational maintainability.
The Codebeamer 3.3 - SCM integration is a significant step forward, with streamlined change package creation and synchronization, webhook-based notifications, and improved OSLC-based collaboration between the tools.
Key Highlights
Stronger Authentication with OIDC – Phase II
  • Integrations
    • Project, Excel, Visual Studio, Eclipse, Jenkins, Git
  • Update C & Java API infrastructure for user-interactive grant flows
  • OAuth token authentication for SMTP Configuration
  • Service Principal
    • FSA/Proxy to Main Server, SI to IM Server, Staging Server to Admin Server, IM to SI - Source trace, links,
    • Jenkins & Git to Main Server
    • OSLC Integration - Suspect Identification or trigger infrastructure
  • PingFederate, OKTA, Entra ID
  • IBM Security Access Manager (ISAM) is no Longer Supported.
SCM Updates
  • Create and sync change packages for Codebeamer 3.3 Items
    • Added support for creating a change package for Codebeamer Items in PTC RV&S Client GUI
    • Added support for webhook triggers in PTC RV&S to notify changes in changes package events to Codebeamer.
  • Server Stability and Throughput Improvements for Data Transfer
    • Introduced automated assignment of DTS profiles based on network latency when using a proxy server. This enhancement removes the need for manual DTS profile configuration.
  • Introduced a new option to resynchronize an exact instance of a shared subproject in the sandbox.
Collaborate – OSLC
  • Added support for Codebeamer Delegated UI to access Codebeamer 3.3 resources.
  • Introduced a new filter in the PTC RV&S Delegated UI that allows users to preselect the document(s) to search requirements within it.
  • Added support for OTHER type of OSLC server to enable integration with tools beyond the PTC Family of products.
    • Added a New Generic OSLC Client to connect with OTHER OSLC Servers
Customer Feedback
  • IBPL Field Character Length
  • Filter White space in Swing, CLI & API
  • Option to Resynch with exact member instance
  • Document View Scrolling speed improvements for Documents with images
  • Copy content from one RTE field to another
Platform Updates
  • HTTP2 Protocol extended to SCM [Client, Proxy, Server]
  • Windows Server 2025
  • RHEL 10
  • Microsoft Office 2024
  • MathWorks Matlab Integration 2025a&b
Documentation
Download
For reference, here is a link to the 13.4 Release Announcement to check on OIDC Phase I details.
