Dec 7, 2018 1:02 PM UTC
PTC si viewprojecthistory cli vs. webservice
The command „si viewprojecthistory -P xxx/project.pj --fields=date,labels” works just fine with the cli, but if use the webservice
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:gen="http://webservice.mks.com/2009/Generic" xmlns:sch="http://webservice.mks.com/2009/Generic/schema">
 <soapenv:Header/>
 <soapenv:Body>
 <gen:command>
 <!--Optional:-->
 <arg0 TransactionId="x">
 <sch:Username>x</sch:Username>
 <sch:Password>x</sch:Password>
 <sch:Application>si</sch:Application>
 <sch:Command>viewprojecthistory</sch:Command>
 <!--Zero or more repetitions:-->
 <sch:Option Name="project">xxx/project.pj</sch:Option>
 <sch:Option Name="fields">date,labels</sch:Option>
 </arg0>
 </gen:command>
 </soapenv:Body>
</soapenv:Envelope>
i get followig Response
<env:Envelope xmlns:env="http://schemas.xmlsoap.org/soap/envelope/">
 <env:Header/>
 <env:Body>
 <env:Fault>
 <faultcode>env:Server</faultcode>
 <faultstring>MKS170064: The command succeeded but there was an error processing the output in the web services layer.</faultstring>
 <detail>
 <ns1:MKSException class="com.mks.api.response.APIException" implication="MKS170064: The command succeeded but there was an error processing the output in the web services layer." xmlns:ns1="http://webservice.mks.com/2009/Generic/fault">Invalid valuelist type: "null".</ns1:MKSException>
 </detail>
 </env:Fault>
 </env:Body>
</env:Envelope>
Dec 10, 2018 9:37 PM UTC
I think this might be caused by the si viewprojecthistory command not being a Published API command. I get the same error on 12.0 using the Generic wsdl.
