RE: PTC Integrity - Change a report
Hello together,
we use a report to compare two baselines with each other and show the differences between the two states (differences of the content and the values of the attributes).
Now I want to change the report because we've got new attributes and they should also be shown in the report.
How can I add the new attributes in the report to compare the changes??
Thanks, Michaela
    Hello Michaela,
    You will either need to modify the report recipe, or you will need to modify the query used for the report. Please see the section titled "Creating and Managing Reports" in the Server Administration Guide appropriate to your release of Integrity.
    Kael
