Real name of the"Title" field
With the im viewissue command I can easily get the fields and the names of a "test case". I get the fields and the values like on the GUI, for example Title and Content. The problem is: there are more Title and Content fields in the system. If I run the "im exportissues" with the --fields=Tittle,Content, I get the other Title and Content fields.
Where can I find the real names for the fields?
Thanks in advance!
    pmerkleAnswer
    field names are unique within an Integrity Server instance. But for a field, beside the field name there is also the "display name".
    You can see that in the Admin Client when you edit a field.
    By default the field name and the display name are identical. But for an existing field the
    display name can be changed.
    Peter
    pmerkle5-Regular MemberAnswer
    Peter
    Hello Istvan,
    If Peter's answer helped you resolve your issue, could you mark it as correct by clicking on the Correct Answer button on his post? This lets other people who might search for this question know that his response solved your problem, as well as people who are currently looking at unresolved threads.
    If Peter's response did not help, could you explain what your difficulty with it is, or the problem you still face, so that we can all help you get to an answer?
    Kael
    ikeri1-VisitorAuthor
    I think the Admin Client need higher acess right than I have, but our admin gave me the table structure with field names, so I can choose the fields for my query.
    Thanks for your answer
    regards Istvan.
