relationshipgroupby in report recipe
I have the following in a report recipe:
<!-- Walk doc -->
<%beginrelationshipsdetail Query[(walkdocordered[<%<%builtin ID%>%>])]%>
<!-- Walk relationship to find STO -->
<%beginrelationshipsdetailL2 Verified By%><%filter%>(field[Category] = "MOP Eval Criteria")<%endfilter%>
  <%beginrelationshipsdetailL3 Query[(walk[<%builtin Contained By%>]<%RelationshipL2 <%builtin ID%>%>)]%><%filter%>(field[Category] = "STO")<%endfilter%>
   <%relationshipgroupby <%RelationshipL3 ID%>%>
    <tr>
     <td> </td>
    </tr>
   <%endrelationshipgroup%>
  <%endrelationshipsdetailL3%>
<%endrelationshipsdetailL2%>
<%endrelationshipsdetail%>
The relationshipgroupby never seems to do anything. It's not even processed when I run the report. The tags still stay as-is in the output html. I want to group the items returned in the L3 query. How do I make this work?
    Hi Nolin Borrero Jr.,
    Since you are in Level 3 i think you need to set the correct Level. Also, you can't use <%RelationshipL3 ID%> in that context. You group by field(name) and what you are doing is inserting a specific id.
    You can either do it as below (select the group by field in the Report Wizard) or set the Fieldname directly.
    <%relationshipgroupbyL3 &groupby%>
    <%endrelationshipgroupL3%>
    Dominik
    Dominik
    When I do that, it does seem to process it but the report is blank. Any idea what that might indicate?
