Nov 20, 2018 3:30 PM UTC
Replacing actor on sequence diagram without redrawing
For various reasons I have ended up with two actors in Integrity Modeller that are meant to be the same.  The incorrect one is used on many sequence diagrams.
Is there a way to replace the actor (either globally or on a diagram-by-diagram basis) without having to drag the correct actor on and redraw all of the Flows that go to that actor?
Thanks.
